not able to track versions; option is grayed out
asked on April 7, 2022
New to LF and scanning. I am trying to understand versions, but seems that I am missing something. The option is grayed out. What might be the cause? I am working with the LF Windows client, v 10.2.1.998.
replied on April 7, 2022 • Show version history
Check under Admin Console:  Repository Options > Settings > Lock version tracking.
You likely have the option marked to "Prevent users from placing documents under version control".
Note: I checked this setting in my own environment which is running Server Version 11 - it's possible it may be different on 10.2.
