inline-block code running together
asked on March 17, 2022
I have fields that need to be in a row of three (not a table, just fields beside each other). Immediately following this row of three, I have another set of fields that need to be in a row of five.
Using CSS, I configured the first row as an in-line block for each row. It worked.
I added the CSS for the next row, but it would not work. While I was trying to figure out what happened, I removed the code for the first row and suddenly the second row worked.
When I put all the code back in, it won't work.
I figure the first code is running into the second, but I'm not sure how to make it stop. Any Ideas?
FYI... I am slowly learning how to code the forms, but am not an expert by any means.
replied on March 17, 2022
It's difficult to determine what is going wrong without seeing the code you are using.  Would you mind sharing?
Alternately, here's how I would do it.
Using this CSS, add the thirdWidth class to all fields in the row where you want 3 items, and add the fifthWidth class to all fields in the row where you want 5 items:
.thirdWidth {display : inline-block; width : 33%;}
.thirdWidth .cf-field {min-width : 80px;}
.fifthWidth {display : inline-block; width : 20%;}
.fifthWidth .cf-field {min-width : 80px;}
replied on March 28, 2022
I managed to fix it just by using a CSS class, rather the the #q references for the three in a row. I'm not sure why that made a difference, but it did. The rest of my code worked fine with the #q references.
Anyway, got it working. Thanks.
