Token Editor using Apply Index for "all values separated by a comma" to get multiple values for my workflow
asked on October 18, 2021
I'm having trouble getting a forms checkbox choices into a workflow token as multiple values so that I can have shortcuts put into multiple folders.  I have used the "List of All Checked" to save in a template field when it saves a copy of the form into the repository.  The workflow then picks up but the token editor can't seem to separate out the choices by comma.
replied on October 18, 2021
Hi Connie-
You're close, but what you have selected is used to split up multi-valued tokens in Workflow. What you want is the Apply Function area and then choose Split. You can then enter the comma as the split character/string. Note: you may want to add a space after the comma in the Split.
replied on October 20, 2021 • Show version history
Perfect!  This is working now!  Thank you!
