I have found two ways of adding a multiple selection option to drop-down lists. One makes uses of Select2 the other is used on a normal selection drop-down. For my form the drop downs are filled from a look up. I discovered what I feel is a big issue and wanted to see if anyone knows how to fix it.
What is happening when I use either of the ways I mentioned to create a multi-select, it makes it so when the submit button is clicked that even if there are required fields without data the form still submits as if it was valid. I can tell the validation is happening because for a split second I see those with missing data turning red and showing that a value is required, but then the form submits anyway.
Code I used for the Select2 multi select
JavaScript
$(document).ready (function () {
/* START: Select2 - allow better searching of a Drop down and force user to */
/* select from available list */
/* the function ApplySelect2 can be moved to the global functions*/
function ApplySelect2() {
$.getScript('https://<<path to code>>/js/select2.min.js', function () {
$('.select2Dropdown select').select2({
placeholder: "Enter Department",
width: "370px",
allowClear: true
$('.select2DropdownMulti select').select2({
placeholder: "Enter All Department",
width: "370px",
allowClear: true,
multiple: true
$('head').append('<link rel="stylesheet" href="https://<<path to code>>/js/select2.min.css" type="text/css" />');
ApplySelect2();
/* applies the format when a new row is added to a table or a collection */
/* NOTE: if you have several tables or collections then you may want to */
/* change this so it only gets called for those tables or collections */
/* that use the select2. Or even removed the next 3 lines of code if */
/* there are no select2 fields in tables or collections. */
$('.cf-table-add-row, .cf-collection-append').on('click', function() {
ApplySelect2();
}); /* END: $(document).ready (function () { */
Code I used for the normal multi select
CSS
.dropdownMulti select {
height: auto;
JavaScript
/* Wait until after the lookup is complete */
$(document).on('onloadlookupfinished', function(event){
$('.dropdownMulti select').attr('multiple', true);
}); /* END: $(document).on('lookupcomplete', function(event)*/
So does anyone know how to fix this issue so I can use at least one of these options?
