monitor running workflows
asked on June 22, 2021
Hello,
There is a way to monitor the workflows in execution when they exceed a certain execution time that allows them to be automatically canceled due to excess time in the execution.
replied on June 22, 2021
Not quite, but you can achieve that behavior. You can add a deadline activity to your workflow where the current activity happens in the main branch and you terminate the workflow once the timer in the deadline branch expires.
Thanks Miruna
I am going to carry out the test, but the query I made corresponds to the fact that: randomly and not frequently one or two workflows are left on hold, it is not a specific flow.
I would suggest opening a support case so we can investigate the cause of the issue for those situations.
