Using GUID as URL Parameters
asked on October 16, 2020
I am attempting to test out a solution for an  public survey/application process that may require changes to the form. I was directed through a Laserfiche employee on the “Answers” Forum to try passing the form field values a URL parameters with the use of GUID and a table. I have the workflow setup to store the simple 4 values into the table I also create a field on the form called “GUID” and set it by default to be the instance ID.
Everything seemed to work as expected except I cannot get the URL parameters to fill the expected fields with the value I set. I even have tried manually inputting the value for the GUID field. I have screenshots below to showcase what I am seeing.
I also attempted the URL parameter route with the Contact Name field and still did not get the field filled with the value I set in the URL..
Any help is appreciated.
Manual attempt at assigning the GUID field
Manual Attempt with another field (Contact Person Name)
replied on October 16, 2020 • Show version history
Unfortunately you cannot pass values into collections or tables at this time.
See this portion of the  help file under "Is it possible to pre-fill the fields on a form by passing in URL parameters?" for more information.
Also, it looks as if the GUID is a read only field. Read only fields cannot be filled in by passing values through the URL.
3 0
