Discussion
Discussion
Not able to browse using Iframe with Weblink
posted on June 2, 2020
When using an iframe with Weblink, the iframe will load the browse page but not allow the user to open any folders.  When using the same code with Web Access, the user is able to browse folders and open documents.
<iframe src="https://servername/laserfiche/Browse.aspx?&amp;mode=embed" width="750" height="500"></iframe>
<iframe src="https://servername/weblink/Browse.aspx?&amp;mode=embed" width="750" height="500"></iframe>
I've tried with including the dbid for Weblink and without but it is not working either way.
replied on June 2, 2020
Hi Jen,
Please implement the workaround for WebLink from https://support.laserfiche.com/kb/1014094/additional-configuration-for-chrome-80 and see if that addresses the matter.
Regards
