asked on July 22, 2019
Hi all,
I need your help to create a specific chart using sdk (vb).
This is what I have.
and this is what I need.
I'm using tokens and SDK from Workflow.
Imports System
Imports System.Collections.Generic
Imports System.ComponentModel
Imports System.Data
Imports System.Data.SqlClient
Imports System.Text
Imports Laserfiche.RepositoryAccess
Imports System.Windows.Forms.DataVisualization.Charting
Imports System.Drawing
Namespace WorkflowActivity.Scripting.Générerlegraphique
'''<summary>
'''Offre une ou plusieurs méthodes qui peuvent être exécutées au moment de l'exécution de l'activité de scriptage du flux de travail.
'''</summary>
Public Class Script1
Inherits RAScriptClass102
'''<summary>
'''Cette méthode est exécutée quand l'activité est effectuée.
'''</summary>
Protected Overrides Sub Execute()
'Rédigez votre code ici. La propriété BoundEntryInfo accèdera à l'entrée, RASession obtiendra la section de Repository Access
'Get the tokens for values and labels...
'################### DEBUT SERIE
Dim valuesToken as List(Of Object) = Me.GetTokenValue("ChartValues")
'################### FIN SERIE
Dim labelsToken As List(Of Object) = Me.GetTokenValue("ChartLabels")
Dim count As Integer = valuesToken.Count-1
'Convert the multivalue tokens to arrays...
Dim chartValues(count) As Double
Dim chartLabels(count) As String
For i As Integer = 0 to count
if CDbl(valuesToken(i)) > 0 Then
chartValues(i) = CDbl(valuesToken(i))
chartLabels(i) = labelsToken(i).ToString
end if
Next
'Create a new chart...
Dim chart As Chart = New Chart()
chart.Width = 690
chart.Height = 460
'Add a title to the chart...
Dim title As New Title(Me.GetTokenValue("ChartTitle"))
title.Alignment = ContentAlignment.TopLeft
title.Font = New Font("Arial", 14, FontStyle.Bold)
chart.Titles.Add(title)
'Add the legend for the data...
Dim legend As New Legend(Me.GetTokenValue("LegendTitle"))
chart.Legends.Add(legend)
'Create a new data series and set the chart type to a pie chart...
Dim series As Series = New Series("Elémentaire")
series.ChartType = SeriesChartType.StackedColumn
series.IsValueShownAsLabel = False
chart.Series.Add(series)
'Bind the labels and values as datapoints...
chart.Series("Elémentaire").Points.DataBindXY(chartLabels, chartValues)
'Create a new chart area and add it to the chart object...
Dim chartArea As ChartArea = New ChartArea()
Dim yAxis As Axis = New Axis(chartArea, AxisName.Y)
Dim xAxis As Axis = New Axis(chartArea, AxisName.X)
chartArea.AxisX.Interval = 1
chart.ChartAreas.Add(chartArea)
'Now write the chart image to the document...
Using docInfo As DocumentInfo = Me.BoundEntryInfo()
'Read the chart image into a byte array...
Dim imageData() As Byte
Using ms As New System.IO.MemoryStream
chart.SaveImage(ms, ChartImageFormat.Tiff)
imageData = ms.ToArray
End Using
'Lock the document and append a blank page...
docInfo.Lock(LockType.Exclusive)
Dim pInfo As PageInfo = docinfo.AppendPage
'Write the image to the new page...
Using writer As System.IO.Stream = pInfo.WritePagePart(PagePart.Image, imageData.Length)
writer.Write(imageData, 0, imageData.Length)
End Using
'Save and unlock the document...
docInfo.Save()
docInfo.Unlock()
End Using
End Sub
End Class
End Namespace
Thank you for your helps.
Regards
