When using checkboxes how can I add a Quantity box beside of it?
asked on June 21, 2019 • Show version history
Have set up a form where customers can select which item they purchased so they can receive a rebate. I am trying to figure out beside of each item how I can have a field where they can enter the quantity. Sometimes landlords will purchase 2 dryers or 2 ranges and we need customers to be able to add in that information.
replied on June 21, 2019
I might use a table. You can default all quantities to 0 and they can mark 1 or more based on what they got.
Item                          | quantity | subtotal
Primary heat $400 |      x          |  =400*x
Range $125             |      x          |  =125*x
