Save Check box values to SQL
asked on June 11, 2019 • Show version history
I have a form where I list a bunch of counties and I assigned them values like C1, C2, C3. I would like to write these values to SQL when they are selected. Currently I have them writing to SQL as a single line but I'l like each value checked to be a separate line entry in SQL. Right now I'm reading the values from the template but I've tried the Retrieve Business Process Variables task but I couldn't get that to work either.  Here is what I have so far. Thanks
replied on June 11, 2019
That's likely because you're iterating over a single value token. I'm guessing the field you're reading in Retrieve Field Values is not a multi-value field?
If you create a multi-value token from your "county" field by splitting it on the comma, then you can iterate over this multi-value token and have the individual values of the checkboxes.
replied on June 12, 2019
Thanks for the response Miruna.
I set the token to a multi value but how would I split by the comma. I've attached screenshots of the workflow. Also should I be using the For Each Value tool? thanks Joel
Workflow.docx (404.09 KB)
replied on July 29, 2019
Sorry for the late reply.
You don't need to create an extra token from the multi-value field. You can use %(RetrieveFieldValues_Service Area_All) directly in For Each Value.
When you set the County field in Insert Data, use the current value token for itgenerated from For Each Value. (You are using %(token 1) which is a multi-value token in a single value field, so Workflow uses the first value of it since it doesn't know which one you want)
