help with configuration
asked on March 13, 2019
The institution has just acquired the product, could someone help me configure it correctly in windows server 2008 and work it from another pc? Are there process templates that you can try for free? thanks for your help.
replied on March 13, 2019
Hi José,
You may find information on how to do this on the help files:
https://www.laserfiche.com/support/webhelp/Laserfiche/10/en-US/administration/#../Subsystems/LFAdmin/Content/Laserfiche_Help_Center_rev.htm
However, your Solution Provider (whomever sold the solution) are in charge of performing initial setup.
