Setting Cut of for Terminated Employees
asked on November 8, 2018 • Show version history
I will have to set a cut off date for a terminated employee in the repository. How do I do that please? So that 5 years from date of termination, the record will be eligible for destruction. Thanks.
Priya
replied on November 8, 2018
Hi Priya,
To set a termination date, you should make sure your cutoff instruction for the record type is an event type. That way you'll be able to define events that need to be marked with a date to determine cutoff eligibility, so in your case you would have an event called "Termination," or something similar.
For the retention half of the equation, you will need to create a retention schedule that keeps your record for 5 years, then goes into whatever final disposition action you choose.
These two elements used in conjunction should give you the retention policy you are looking for.
replied on November 9, 2018
Thanks
