Hi,
I have a Form in LF Forms with several user's tasks assigned to the same person and for each of them, I have checked the boxes "Automatically load the next task if the same person is assigned to it" and "direct approval".
When the user opens the task and sees the form and approves it , the function "Automatically load the next task if the same person is assigned to it" works fine and the form for the next task is displayed.
But if the user wants to use "Direct Approval" from the detail pane of the task without opening the form, the function "Automatically load the next task if the same person is assigned to it" doesn't work and the user has to refresh his task's list to see the new task (same behaviour as if "Automatically load the next task if the same person is assigned to it" was not checked).
Is there a way to Load the next task even when I validate with Direct Approval
Thanks for your help
