Scanconnect not showing in scan engine list for Quick Fields 10 Scanning
asked on September 10, 2018
I just installed QF 10 Scanning on a station, along with LF Client and Scanconnect 8.3  I tested scanning through LF client, and it works perfectly.  When I open Quick Fields Scanning, though, the dropdown for the scan engine only shows WIA or TWAIN.  Any ideas?
replied on September 11, 2018
Can you try re-installing Quick Fields Scanning? If that doesn't work, I recommend opening a support case.
