Not Filling Required Fields
asked on August 31, 2018
In Forms 10.3, I have a upload field that is required. But when the user selects Reject on the Task, the form should not ask them upload anything. As it is a required field, it is asking the user to upload even for Rejects. How can I solve this using Javascript or any other method please?
Thanks
Priya
replied on September 4, 2018
Usually what I would do is only include a Submit button on the form and handle Accept/Reject with a radio button or dropdown on the form.
If the user selects "Reject" then use a Field Rule to hide the upload field and ignore all data. Once it is hidden Forms will ignore the required attribute.
Thanks
