I have a form need user to print it from web after submit, The form has a read only field, when user submit the form and try to print that read only input not appear.
Field Name is: Request No:
What version of Forms are you using?
After submission, can you see the inputted value in Forms?
How are you printing the form?
Hi Jared,
I use forms version 10.2.1.246
After submission i see all inputted value except read only inputted, but can see it's label.
I add print button from Message Start Event in process Diagram window then after submit form i print it.
Also label background color not appear in print.
This is working for me on my copy of 10.2 using the same field name and configuration. Please open a support case so we can take a look at your process and investigate the cause of the issue.
