Label Color in Collection When Required
asked on August 20, 2018
I have seen a couple of posts and found the JavaScript below to change the color of the field label only when the field is required.
2
  $('.cf-required').parent().css('color', '#cd2026');
3
This has been working well for me until I tried to put required fields in a collection.  The first set of fields gets colored labels but any additional sets don't get colored labels.  Ideas on how I would get all the additional sets to be colored?
replied on August 20, 2018
You need to make the browser check for required fields whenever the 'Add' button is clicked. My modified function below has an additional function that checks for this:
  $('a[ref-id="q20"]').click(function() {
Replace "q20" with the qN associated with the "Add" button. For example, in the following screenshot, the browser's Inspect tool shows the value of ref-id for that button:
Thank you so much.  Works perfect.
