Hello,
I need to change System Field like Creator, Created Date, Modified By and Modified Date using SDK.
If we can Import Documents using SDK then it will automatically set the Session User name and system Date time for Creator and Created Date Time but i need to set field value using SDK but not used for session user name and created date.
is it possible to update field using SDK?
Thanks
