Identity Provider - Failover Domain Controller
asked on June 27, 2018
LFDS version 10.3.0.110. Is it possible to edit the list of Failover Domain Controllers for an identity provider.  I can delete entries but unable to save any changes.  Is this normal?  I have full Admin permissions.
replied on June 27, 2018 • Show version history
Hi Chuck,
This is a bug (reference# 97200). In LFDS 10.3.0.110, save button won't be enabled if you only update failover domain controllers field. We have a plan to fix this issue in future release. In the meantime, please try update other fields (for example, enable ssl or use different credentials) along with your Failover Domain Controllers changes, save.  And then revert back other changes.
Thanks,
Rufei
