asked on May 21, 2018
I am trying to get a QF Session in LF 10.3 to save where a required drop down metadata field is getting its value from the LF Capture Engine field equivalent. I am migrating to this version of LF QF 10.3 from 9.2. When I set the LF capture engine value in the metadata field and save the QF Session it saves. But when I open it back up, the LF capture engine value is wiped out and the Red Exclamation point is again displayed for the meta data field in the QF Session. It appears to be happening in any LF QF Session I have a drop down for. Any idea why I can't save the LF Capture engine value in the drop down list. It is the same meta data field from the LF Capture engine.
0
0
