Hi All,
What is a real difference between "Child Documents" and "Electronic Count" in Laserfiche Folder Properties?
I am migrating files from a windows folder to the repository using "Import Agent". After the import, assuming there is no error should the number in "Child Document" be the same as the total documents in the windows folder or it is the "Electronic count" number that should match the number of documents in the windows folder.
Thanks
