space between fields when placed side by side
asked on September 19, 2017
I have a collection fields that I need to place side by side.  I have scoured LF Answers and have found many answers.  Now, I am thoroughly confused.  I have tried a variety of options, but nothing seems to work. If I get the fields closer, the title is condensed...or, the field input is not big enough.
I have tried changing the percentages, pixel size, label size, field size, and more...I guess I am not getting the proper grouping.
I want to remove the part indicated above.  Can anyone explain to me how to put two fields (I need to add more fields at a later stage) in an inline block, but not have all the space?
If there is a whitepaper, video, or anything out there that explains how to space fields like this, I would love to know.  I had trouble with spacing before, but it was with a table.  I ended up getting help with that, too.
Please help.
Thanks in advance.
replied on September 19, 2017
Use Float Right on the righthand field, then use Margin Right to shift it away from the edge. Inline-block is way too much of a headache when trying to do what you're doing.
I did something similar like this...
In CSS
/*Displays two fields per line*/
.TwoPerLine{display: inline-block; width:50%;}
.TwoPerLine .cf-medium{width:120%;}
.TwoPerLine img.ui-datepicker-trigger {display:none!important}
and to hide the label in the second "column"..
/*Hide Labels*/
.Hide .cf-label{display: none;}
Looks like the attached image
replied on September 20, 2017 • Show version history
Maybe you have other styling interfering with things? I tried the following code, which is essentially the same as yours, and it seemed to work correctly.
.Hide .cf-label {
  display:none !important;
.TwoPerLine {
  display:inline-block;
  width:50%;
.TwoPerLine .cf-medium {
  width:120%;
I would open the page up in Chrome and inspect the elements to see exactly what is going on with the element styling.
