updating sql after running process
asked on June 15, 2017
Hi,
I currently have an aspx page written in C# that processes an IT help desk request.  As part of this process, the application inserts a record into a sql table.  Can anyone tell me how to do this using laserfiche?  Where in the process could I do this, and how, exactly would I go about doing this.  I know that you can fill columns on a form using a database connector, and creating look-up rules.  I just was not sure how to enter data collected on the form into sql either during, or after the process runs.
Thanks.......................................................Sheela.
replied on June 15, 2017
Hi Shela,
I recommend using Laserfiche Forms and Laserfiche Workflow. With Forms you have the form..
 The data captured the Workflow sends (Workflow Service Tasks),
https://www.laserfiche.com/support/webhelp/Laserfiche/10/en-us/administration/#../Subsystems/Forms/Content/Service-Tasks.htm#WorkflowServiceTasks
Workflow has an activity to write data to a database.
https://www.laserfiche.com/support/webhelp/Laserfiche/10/en-us/administration/#../Subsystems/LFWorkflow/Content/Resources/Activities/Insert%20Data.htm?Highlight=insert%20data
regards,
Marco.
