Changing Participant for Business Process without restarting the business Process
asked on April 24, 2017
Is there a way to change the trustee/participant for a business process in a running instance without restarting the process?
We have a workflow which has a business process assigned to a participant. We want to update that participant in the running instance without restarting the whole workflow. Is there a way to do this?
replied on April 24, 2017
Hi Rajeshwari,
If I understand you correctly, then I believe the answer to your question is "Yes".
There is an "Update Participants" action in the Toolbox that is placed inside a Business Process Step and which allows you to update the participants assigned to the process.
I hope this helps!
Thank you,
Rob
