Dear All,
in my form design i am using % and not static width, it is displaying fine in the brwoser, but when it is saved to laserfiche, the % is not respected.
i have a multivalue field in a table giving it 41%, in the browser all the information in it is displayed in 3 lines, which is good. but when it is saved to laserfiche, the field (not the td of the table) is getting smaller in width, and the information is displayed in 5-6 lines.
also, i am putting 2 sections side-be-side, displaying well on the screen, but when it is saved to laserfiche, one of the sections moves up a little bit(0.1 inch) which make the display unstable.
Please advice.
Thank you, maher daher.
