Hi,
I have many files in LaserFiche that were loaded in bulk before I came onboard. The filename of each field was stored in a field when the documents were uploaded. The filenames are formatted customernumber_description.pdf. The customernumbers are all 6 digit numbers but some start with a letter. I'm trying to create a workflow that will take the first six digits of each filename (the customernumber portion only) and set that value for a field called Customer Number. Is there way to do this using assign field values. Can this be done?
Thank you all for your help!
