HierarchyID Data Type problem
asked on January 14, 2017
I have sql server Table with HierarchyID Data type Field, i can not add it to external tables in admin console.
i got a message that this data type in not supported?
replied on January 15, 2017
Hi Ayman,
If there's no support for the datatype, you could create a view of the table, either excluding the HierarchyID field of converting it to an nvarchar(4000).
CREATE VIEW NewView AS
SELECT convert(nvarchar(4000),myHierarchyID)
FROM table_name
Then you can configure the view as an external table.
-Ben
thank you i already did that, but i only send it in case laserfiche may fix this problem in the future.
No worries.
