Working with a document locked by yourself, difference between being locked out of it and being able to modify
asked on November 30, 2016
If you open and start working with a document it will be locked by your account but you can still make changes to the document.
From what I understand the only way to lock yourself out of your own document is to open 2 copies of the application. If this were the case would it show as 2 different connections?
Here I have a document locked by someone:
And yet they only have one connection listed under All Sessions
Yet they were unable to add any pages to the document because it was locked by them.
I was trying to explain that two copies of the Laserfiche application would need to be open in order to lock yourself out of a document. At the very least a crashed copy of the executable would need to be running holding the document locked, wouldn't this show up as another connection though?
What is the difference between being able to work with a document you have locked and actually locking yourself out of it. Am I correct that another instance of the entire application is required, does not relate to a new connection?
replied on December 1, 2016
That's not quite right. If the application crashes while holding a lock, then the executable would no longer be running. The server would still have the lock since the application that locked it did not call back to release it.
Was this an image document or an electronic document?
It was a native tiff image. They were trying to add pages by scanning. When the scanning is complete and tries to update the document it was unable to do so because of the locked status. Releasing the lock from the admin console did the trick.
