Banner and Colleague
asked on November 30, 2016
Is anyone aware of any substantial differences between Banner and Colleague in terms of how Laserfiche would integrate with either?
replied on November 30, 2016
Hi Richard,
While I'm not personally familiar with either application, according to our list of confirmed applications it appears that others have had success in integrating with Banner 8.6 and Datatel Colleague 4.4 using Laserfiche Connector. Connector is probably your best bet, unless someone else has made a specific integration between Laserfiche and those applications. You can give it a go with our Test Utility (e.g. if you do not want to commit to purchasing Connector before seeing that it does work) and if it comes up short in some way, feel free to let us know via our Application Compatibility Form.
Hope this helps!
