asked on November 22, 2016
I am comparing to this solution from a competing product:
https://docs.lexmark.com/ImageNow/en_US/7.1/Admin/Print/Fax_Agent_Installation_Guide_7.1.x.pdf
Effectively, it allows you to select documents and send them through a fully featured Faxing agent.
If there is a third party Fax product that can be easily integrated with Laserfiche, that would be great to know. I have a prospect for whom this a key requirement.
I am completely open to "think outside the box" solutions in this situation, so please let me know what you think.
