What is variable for system date for use in Forms?
asked on November 3, 2016
I have an expression I'm using in an Exclusive Gateway to evaluate the monitoring end date against the current date.  At the risk of sounding dense, I'm drawing a blank for the correct variable to use for system date!
replied on November 3, 2016 • Show version history
Hello,
First of all, I'm sorry if I incorrectly understand your question. Please correct my understanding if my answer doesn't answer your question.
You can add a date field into a form, and set the default value of the date field as 'Current Date'. This new date field will have a value of current date. And then in your 'Exclusive Gateway expression', you can use it as 'current date variable'. Expression can be like "/dataset/Monitoring_End_Date=/dataset/Current_Date". (In this expression, 'Current_Date' is the name of date variable which has 'Current Date' as its default value)
replied on November 4, 2016
You have correctly identified my question and provided an answer that is very helpful.  I will have to test this out.  I was able to get this functionality to work (for the most part) using a Timer Catch Event instead of the gateway, but would prefer using the gateway to evaluate the date.  Many thanks!
