Regular Expression Help
asked on October 21, 2016
Hi,
I am ocring a document in QF. I get a token with bunch of values. From this token i am trying to extract the amount with no luck so far. This is part of token value
Late Payment Charge: 0.00
Total Amount Due: * 123,123.87
Your remittance should match the Total
I am trying to extract Total Amount Due but because of presence of * it is not working.
this is what i have so far.
.*Total Amount Due:.*(\d{3},?\d{3}.?\d{2}).*
this works for 123,123.87 but not for 213.87.
Any help is greatly appreciated.
Thanks
Junaid Inam
replied on October 21, 2016
Or better yet,  add a ? quantifier to Scott's RE so it is not greedy
.*Total Amount Due:.*?([\d,\.]+).*
Your pattern explicitly needs the 8 digits to work. You could try something a little less restrictive like
.*Total Amount Due:.*([\d,\.]+).*
Note that if you want to use a literal period, you actually have to escape it (\.). This grabs any continuous string of numbers, commas, or periods. If you want to be a little more restrictive, you could try something like this:
.*Total Amount Due:.*(\d{0,3},?\d{0,3}\.?\d{2}]+).*
Scotts RE looks great but I would replace the * with 2 dots, (for the text Space*Space)  I think it the * will get greedy and to to the end of your text.
.*Total Amount Due:...([\d,\.]+).*
