Does Forms 10 on Rio support SAML authentication. If yes can you point me to documentation on how to configure it?
Forms 10 support use Laserfiche Directory Server to do authentication, you can follow this documentation to configure: https://www.laserfiche.com/support/webhelp/Laserfiche/10/en-US/administration/#../Subsystems/Forms/Content/Administration/Configuring-User-Authentication.htm
If you want to switch from Laserfiche Server authentication to Laserfiche Directory Server, you can refer to https://support.laserfiche.com/kb/1013710
So basically it does not support SAML. Are there any plans to support it in future ?
Laserfiche Directory Server is the only SAML provider Forms supports, it doesn't support using any external SAML providers. And there is currently no plan to support external SAML providers yet.
We're looking at expanding the supported identity providers in the Directory Server first to ADFS and eventually to Shibboleth. I don't have a release date for either one at this time.
Do you have a preferred provider in mind?
Hi Miruna,
Sorry to jump in on the thread, we have a number of clients wanting ADFS.
