How to set a default engine options dialog using Scan Connect?
asked on October 12, 2016
When scanning I set my scanning options to Black and White, Auto Detect Page size, and Skip Blank Page. I save those setting as B/W Auto. It scans great! But when I log out and then log back in, it defaults back to Simplex. It does this every time I change to Skip Blank Page setting. But when I choose Duplex and log out and log back in, it will default to Duplex (my last scanned settings)
How do I set my default to Black and White, Auto Detect Page, and Skip Black Page? So every time I scan I don't have to select it.
replied on October 12, 2016
Make sure in Windows you have full control to the following folders and files:
C:\Windows\Pixtran
C:\Windows\Temp
C:\Windows\setscan.ini
If you don't have rights to these, scanner settings won't stick.
