Read Content of an Excel document from repository using workflow SDK
asked on August 13, 2016
Is it possible to read the content of excel sheet which is stored into Laserfiche repository using workflow SDK 9.2 ?
A workflow "search" activity looks  for a file from the repository and parsed that excel sheet to SDK script activity in order to read the cells and insert them into SQL database hosted on another server ?
replied on August 14, 2016
The Workflow SDK is for interacting with the Workflow Server. You need the Laserfiche SDK to read documents from the repository. You'll need an ODBC or OLE driver or the Office SDK to process the contents of it.
replied on August 15, 2016
Thanks for reply, here you go what iI did
I am trying to build custom activity to read excel file from the repository as I mentioned, and I've added Interop.LFSO90Lib.dll, Laserfiche.RepositoryAccess.dll, & Laserfiche.DocumentServices.dll from SDK.
finally, I added this custom activity into Workflow designer and built small example;
1- Search for Document "Excel"
2- Rn the custom activity for each found document
3- this custom activity export document into Windows Temp folder and then I will do the required.
moreover, once I run it I got the below error;
15/08/2016 12:26:11 Tameen Custom Activity Unable to cast COM object of type 'System.__ComObject' to interface type 'Laserfiche.RepositoryAccess.IDocumentContents'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{0487007E-50D3-3C5C-BBDE-E6D876AFB254}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Platform version: Laserfiche Server, Laserfiche  workflow, and Laserfiche SDK  is 9.2
I can't tell without seeing your code, but it looks like you're mixing and matching LFSO and RepositoryAccess calls. That's not expected to work. If you're running Workflow 9.2, stick with RA calls only.
