Volume Consistency Checker input string was not in a correct format
asked on August 4, 2016
Trying to run Volume Consistency Checker 8.0.0.3 on LF 9 repository and it is giving me an error = Input string was not in a correct format.
From the run log of the utility I see this:
DefaultSource    Information    0    ValidatePage(1, E:\GABC-VOLU\, ImageFiles, False)
DefaultSource    Information    0    Calculating storeidend based on the volume paths
DefaultSource    Information    0    Hex storeidend = SubscribrLogsSubscriberLogsGABCIIS0100
DefaultSource    Information    0    Attempted to get integer from the hex string: SubscribrLogsSubscriberLogsGABCIIS0100
DefaultSource    Information    0    System.FormatException: Input string was not in a correct format.
   at VolCon8.Main.GetIntegerFromHexString(String str)
   at VolCon8.Form1.ValidatePages(Int32 volid, String volpath, ValidateType type, Boolean IgnoreNonLF)
   at VolCon8.Form1.ValidateVolume()
replied on August 4, 2016
The utility assumes the subfolders are all strings of hex digits and doesn't expect that you'd have files that didn't initially come from a Laserfiche volume. Do you have a path in there for \SubscribrLogs\SubscriberLogs\GABC\IIS\01\00 or similar (maybe with different breakdown)?
replied on August 5, 2016
The Image Path, Text Path and EDocument Path were loaded into the dialog box with E:\GABC-VOLU.
I changed them all to E:\GABC-VOLU\00 and it is chugging away now.
Thanks for the clue about the folder names.
I was one too high in the hierarchy and under that folder were the Audit folder, Logs, Search, etc. as well as the 00 folder.
Addendum - I looked at the report and it was showing every image as missing so I checked the path and it had two slashes in the path so I re-ran with:
E:\GABC-VOLU\00
(no trailing slash)
Still no joy.  It runs but it reports all images and texts in error because the path is wrong.
That is to say, if the image is in E:\GABC-VOLU\00\0A\0A it will report it as missing because it is looking in E:\GABC-VOLU\00\00\0A\0A.
Our folder structure at the highest level is this:
 Directory of E:\GABC-VOLU
07/13/2016  02:40 PM    <DIR>          00
08/05/2016  11:39 AM    <DIR>          AUDIT
02/10/2012  05:39 PM    <DIR>          e00
10/22/2014  04:59 PM    <DIR>          LOGS
08/05/2016  11:29 AM    <DIR>          SEARCH
11/25/2013  05:02 PM    <DIR>          SEARCH8
08/02/2016  05:02 PM    <DIR>          TEMP
07/28/2016  04:13 PM    <DIR>          WF
The error I am getting, Attempted to get integer from the hex string: SubscribrLogsSubscriberLogsGABCIIS0100, looks to me like it has gone into the WF folder -
 Directory of E:\GABC-VOLU\WF\SubscriberLogs\GABCIIS01
08/05/2016  10:36 AM    <DIR>          73e31147-6085-41ee-a78c-2a97beb43645
It looks like your volume was misconfigured and ended up in the repository root (ie, the repository root is set to E:\GABC-VOLU and the volume is also set to E:\GABC-VOLU). This is not a problem for the LF Server, but the utility does not expect that. It looks like the Workflow volume was also put into the repository location (the "WF" folder where the SubscriberLogs are residing).
Probably the easiest thing to do now would be to separate things out first, then re-run the Volume Consistency Checker.
1. Run through the WF Server configuration wizard and move the WF volume to a location outside of the E:\GABC-VOLU folder. This will move all the file in the "WF" folder out. (Caveat: this is a guess based on the screenshot, it's possible that your WF volume is already in a different location and this is just a manual copy of its files somebody made.)
2. Create a new volume into its own folder (something like E:\GABC-VOLU\MyNewVolume) and migrate all documents in the repository to it.
3. Run the consistency checker on the new volume.
If any of this sounds complicated, have your reseller open a case with Tech Support and they'll help you sort it out.
GABCIIS01 is the server name.
GABC-VOLU is the volume name.
From GABC-VOLU\00 on down the folders are all hex as far as I can tell.
Is the utility using server name for volume name?
