Tables and calculations: copy value from column 1 to column 2, on the same row
asked on June 21, 2016
Forms 10.1 Update 1
I'm playing with the out-of-the-box calculation functionality using tables.
The help files state that Forms uses the same OpenFormula standard as Excel.
In excel, if you want to copy a value from one cell to another, you can use a simple formula referencing the source cell, e.g. =A4
When I try this on a form table though, it behaves oddly and appends the value of the subsequent cells to all cells. For example, here's the first row:
When I entered 15 into the Sub-Total field, it correctly got copied to the Amount field. Great.
But here's the second row when I click Add line item:
OK, why did the value get copied into the Amount field in the second row?
When I enter 30 into the Sub-Total field, this happens:
Is there a way to specify in the formula that the value should only be taken from the specified field in the same row as the target field?
I looked at the documentation. Unfortunately, the examples provided seem very rudimentary and they are not helpful.
replied on June 22, 2016
For this table
I was able to achieve error that you were getting by adding this in the calculation field for col2
=TEXT(table.col1)
this would append all the values of col1 in the col2
and then i was able to fix that using
=TEXT(INDEX(table.col1,ROW()))
