Problem with port 443
asked on April 15, 2016
Hi,
To make a long story short, we are a small organization with a limited Infractructure. That is to say that we have a development server and a production server where all Laserfiche component are installed. This means that web access and server are on the same VM. Recently, I installed the SocialBPM on the development server. I configured it to use SSL and I added a valid certificate that I link to port 443. The problem is that SocialBPM need this port to work but I've realized that the service Laserfiche server is already listening this port. Is there a way to configure the server and the SocialBPM on the same machine?
Thank you
replied on April 15, 2016
Hey there,
Here's the information about ports (and further configuration) I was referring to.
https://www.laserfiche.com/support/webhelp/Laserfiche/10/en-us/administration/Default.htm#../Subsystems/LFAdmin/Content/Using_SSL_TLS.htm
Configuring SSL/TLS with Laserfiche
To use SSL or TLS with Laserfiche, you must configure the Server computer and specify that the users should use SSL or TLS with their client connections. Instructions for configuring the Server are below. To specify that SSL or TLS should be used with Client applications, see Using a Client Application with SSL/TLS.
To configure the Server computer for SSL/TLS
  1. Stop the Laserfiche Server Service. (See Starting or Stopping the Laserfiche Server Service for more information.)
  2. Verify that the prerequisites are in place and the server certificates have been correctly configured.
  3. On the Server computer, open the registry editor.
  4. Navigate to HKey_Local_Machine\SOFTWARE\Laserfiche\Engine\8.0\HttpServ.
  5. From the Edit menu, point to New and select DWORD.
  6. Name the value "SSLPort" and set its value to "443". (If your SSL/TLS implementation uses a different port, provide that port number instead.)
  7. Close the registry editor.
  8. Start the Laserfiche Server Service. (See Starting or Stopping the Laserfiche Server Service for more information.)
Are you getting a specific message from either application?
No error message are displayed. When we try to reach the socialBPM login page it just show nothing. If we stop the laserfiche server service and we try to navigate to the socialBPM we can finaly reach the login page.
Open the LF admin console. Go to the Server Setting node.  What ports do you have set there?
The port listed there are:
Listen port 8080
Notification port 5051
LFAPI port 1888
replied on April 15, 2016 Show version history
What URL are you using when trying to open SocialBPM?  Please type in the exact URL you use.
What is the OS and service pack of the machine where you have both applications installed?
I use https://myservername.mydomain.local/SocialBPM .
My server is a windows server 2008R2 standard with the service pack 1 installed.
With the LF server running, what do you get if you use https://myservername.mydomain.local:443/Socialbpm?
I got the same thing as if I did not have it. But since I add a DWORD registry key that solved the problem.
Thank you for your help.
replied on April 16, 2016
No worries, glad to help.
Hi Alexandre,
On a test server, I have a number of products (LF, WF, Web Access, Mobile, Audit, Answers, Forms) running and all using SSL. Port 80 has been blocked, too.
It's never ideal but it can be done.
When you say you have LF listening on 443, did you do it by setting adding the registry key: SSLPort ?
-Ben
Hi Ben,
Can you precise where to find the registry key you are talking about?
Thank you
Hey there,
Thank you,
This post was very helpfull. It seems that what I was missing was to add the DWORD in the registry. Now everything works fine.
