Hello Community!
I am trIed to use a Script using C# code, the code take some data from Active Directory, but when I try to run the script I got this error message:
"The TLS/SSL host name does not match the host name in the X.509 certificate", as show the image below:
I don't what kind of certificate I must to install. When I tried to run the all workflow I found this other error message:
"The workflow service is not licensed. [0645-WF1]"
I dont know what is the license or certificate I missing, please any help in this is appreciate!
I left the workflow design and the code I am using:
and the c# code is inside in the script:
namespace WorkflowActivity.Scripting.Script
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Data.SqlClient;
using System.Text;
using System.DirectoryServices;
using System.DirectoryServices.AccountManagement;
using System.DirectoryServices.ActiveDirectory;
/// <summary>
/// Provides one or more methods that can be run when the workflow scripting activity is performed.
/// </summary>
public class Script1 : ScriptClass90
/// <summary>
/// This method is run when the activity is performed.
/// </summary>
protected override void Execute()
string userToFind= GetTokenValue("FindUserToModifyValues_Display_Name").ToString();
List<Employee> employees = FindUsers(userToFind);
if(employees.Count>0)
SetTokenValue("employeeName",employees[0].name);
}else
SetTokenValue("employeeName","No employee founded");
public static List<Employee> FindUsers(string userToFind)
string domainName = "TOHO_MAIN_HQ";
var employees = new List<Employee>();
Employee employee;
// Get the current domain context
Domain domain = Domain.GetDomain(new DirectoryContext(DirectoryContextType.Domain, domainName));
// Search for users with display names containing "John"
using (DirectorySearcher searcher = new DirectorySearcher())
// Set the search root to the domain's directory entry
searcher.SearchRoot = domain.GetDirectoryEntry();
// Set search filter for users with display names containing "John"
var instructionToRun= "(&(objectCategory=user)(displayName=*{" + userToFind + "}*))";
searcher.Filter = instructionToRun; // Use wildcard * to find all users with display names
// Specify the attributes to load
searcher.PropertiesToLoad.AddRange(new string[] { "samAccountName","givenName", "sn", "mail", "displayName", "department", "title", "manager" });
// Perform the search
SearchResultCollection results = searcher.FindAll();
// Display search results
if (results.Count > 0)
foreach (SearchResult result in results)
employee = new Employee();
// Retrieve and display user details
string displayName = result.Properties.Contains("displayname") ? result.Properties["displayName"][0].ToString() : "Not specified";
employee.name = displayName;
string email = result.Properties.Contains("mail") ? result.Properties["mail"][0].ToString() : "Not specified";
employee.email = email;
string jobTitle = result.Properties.Contains("title") ? result.Properties["title"][0].ToString() : "Not specified";
employee.jobTitle = jobTitle;
string department = result.Properties.Contains("department") ? result.Properties["department"][0].ToString() : "Not specified";
employee.department = department;
string managerDisplayName = result.Properties.Contains("manager") ? result.Properties["manager"][0].ToString() : "Not specified";
employee.manager = managerDisplayName=="Not specified"? "Not specified" : FindManagerName(managerDisplayName);
var employeeAccountName = result.Properties.Contains("samAccountName") ? result.Properties["samAccountName"][0].ToString() : "Not specified";
employee.staff = FindEmployeesBelowToManager(employeeAccountName, domain);
employees.Add( employee );
return employees;
public static List<string> FindEmployeesBelowToManager(string manager, Domain domain)
var staff = new List<string>();
// Create a directory searcher for users
// Set search filter for the username
var instructionToRun= "(&(objectCategory=user)(samAccountName={" + manager + "}))";
searcher.PropertiesToLoad.AddRange(new string[] { "distinguishedName" });
SearchResult result = searcher.FindOne();
if (result != null)
// Retrieve the distinguished name of the user
string userDn = result.Properties["distinguishedName"][0].ToString();
// Create a directory searcher for direct reports
using (DirectorySearcher directReportsSearcher = new DirectorySearcher())
directReportsSearcher.SearchRoot = domain.GetDirectoryEntry();
// Set search filter for direct reports
instructionToRun= "(&(objectCategory=user)(manager={" + userDn + "}))";
directReportsSearcher.Filter = instructionToRun;
directReportsSearcher.PropertiesToLoad.AddRange(new string[] { "displayName" });
SearchResultCollection directReports = directReportsSearcher.FindAll();
// Display direct reports
if (directReports.Count > 0)
//Console.WriteLine("Direct Reports:");
foreach (SearchResult directReport in directReports)
string displayName = directReport.Properties.Contains("displayName") ? directReport.Properties["displayName"][0].ToString() : "Not specified";
//Console.WriteLine($"- {displayName}");
staff.Add(displayName);
else
//Console.WriteLine("No direct reports found.");
//else
// Console.WriteLine("User not found.");
return staff;
public static string FindManagerName(string managerNameWithComma)
string[] managerSeparatedByComma = managerNameWithComma.Split(',');
string[] managerNameWithCN = managerSeparatedByComma[0].ToLower().Split('=');
string[] managerName = managerNameWithCN[1].Split(' ');
for (int i = 0; i < managerName.Length; i++)
if (string.IsNullOrEmpty(managerName[i]) == false)
managerName[i] = char.ToUpper(managerName[i][0]) + managerName[i].Substring(1);
return string.Join(" ", managerName);
public class Employee
public string name { get; set; }
public string email { get; set; }
public string jobTitle { get; set; }
public string department { get; set; }
public string manager { get; set; }
public List<string> staff { get; set; }
