Turn On Multi Factor Authentication for Client
asked on April 24, 2024
I am using the Windows Client and would like to use the MFA.  I noticed if I turn on the MFA on my account, it will no longer allow me to use the Windows Client.
How are these supposed to work?
I am probably missing a step somewhere.
Thank you!
replied on April 26, 2024
Manuel, I noticed you tagged this post as being related to Quick Fields. Are you asking about Quick Fields or the Windows Client?
Hi Blake,
Thank you for the response.  I was trying to figure out where do I turn on MFA in the Windows Client.
I was talking to some of the Product Info staff at the booth yesterday and they mentioned that I am probably using an older version of the program and that is why I can't authenticate with MFA in the Windows Client.
Do you know where I can download it from?
Thank you!
You can download the latest version 11 software here: Laserfiche 11 - Downloads.
replied on April 29, 2024
Blake,
I upgraded my software to 11 and am still not able to Store the documents in the Repository.
I get an error saying the username and password are incorrect.  I guess the question is, where does the user get prompted in Quickfields to authenticate with the MFA?
Thanks!
